Sondage
Votre avis sur cette option ?
Indispensable
52 (21.6%)
Utile
101 (41.9%)
Pour le confort
36 (14.9%)
Sans avis
45 (18.7%)
A éviter
7 (2.9%)
Total des votants: 225
A A A A Auteur Sujet: (H) Chassis sport, sportswitch et IDS+: vos avis  (Lu 205732 fois)
Hors ligne BabyBoy
Re : (H) Chassis sport, sportswitch et IDS+: vos avis
« Réponse #450 le: 05 mai 2006 à 23:22:03 »
Je reviens pour vous dire (ce soir je fais le controle des points qui font debats) en fait pour resumer il y a 2 types de suspensions sur nos Opel
Soit CDC qui est (copier/coller du TIS)
Electronic damper control (CDC)
From MY 2005 onwards, the electronic damper control, already in use on the Astra-H, will be available for the Vectra-C
The CDC adjusts the damping of the vehicle shock absorbers to driving conditions and prevailing road conditions. The CDC system works here on the "skyhook" principle. The aim of the "skyhook" principle is for variable damping to keep the body of the vehicle as still as possible, independent of road surface conditions. The point of reference here is an imaginary virtual level (e.g. the sky above the vehicle), which is stored as a computing model in the CDC control unit. The body of the vehicle is to move as horizontally straight as possible in relation to this level. All vertical movements are counterbalanced as far as possible by targeted triggering of the individual shock absorbers within milliseconds.
En gros c 'est des suspensions à tarage variable mais sans IDS+
Et il y a l IDS+ : (toujours extrait du TIS)
Chassis system IDS-Plus
The IDS-Plus chassis system (interactive dynamic system) is available as an option on the Vectra-C, model year 2005. IDS-Plus delivers a level of driving dynamics and driving comfort previously unknown in this class of vehicle. The chassis system can be switched into sports mode by a sport button which is to the right of the radio. In this mode the damping becomes harder, the steering transmission more direct and the accelerator pedal reacts even more quickly.
The system shows the following improvements:
1. Improved handling
2. Reduced braking distance
3. Greater comfort
4. No inherent system shortcomings
5. Prevention of unwanted system influence
This chassis system is made up in particular of various components linked to each other.
ABS / ESP-Plus
EHPS steering.
The links are based on the electronic architecture used in the Vectra-C with its three CAN bus systems. The high-speed data bus is used for the signals from the drive and chassis control system, which are especially time-sensitive.
If there are faults in the IDS-Plus system, a control indicator fitted in the instrument lights up while driving. The system then ceases to operate, i.e. only normal vehicle operation takes place without further restrictions.
C'est aussi des suspensions a tarage variable mais la c'est "guidée" electroniquement en utilisant les données du CDC, de la direction assisté EHPS et de l ABS+ESP
Voila voila
Hors ligne David91
« Réponse #451 le: 06 mai 2006 à 09:42:29 »
C'est bizarre j'avais dis ça a une époque et tous le monde m'avais incendié...
Par contre ce qui est bizarre c'est que si les amortisseur sont tous à tarrage variable, pourquoi le SW ne modifie pas la fermeté des suspension en mode sport si tu n'as pas l'IDS+  :bizarre1:
Alors moi je me demande s'il n'y a peut-être pas encore une embrouille Opel France là-dessous... genre "les francais n'auront les amortisseurs à tarage variable que s'il prennent l'IDS+..."  :bizarre2:
A suivre en tous les cas...seule solution, trouver les références des pièces ou démonter une roue pour essayer de voir les amortisseurs "normaux" sans ids+...
Hors ligne marcf78
  • GTC addict
« Réponse #452 le: 06 mai 2006 à 10:49:35 »
Là je suis pas d'accord  :wink:
Oui il y a bien deux types de suspension : avec et sans CDC  :moqueur3:
Le système IDS c'est :
ABS / ESP-Plus
EHPS steering
Le système IDS+ c'est les système IDS + le CDC
Hors ligne nighthawkii
« Réponse #453 le: 06 mai 2006 à 12:28:12 »
ca c'est pas impossible car en fonction des pays l'équipement varie : en France sur le 1.3 l'ESP n'est pas de série, en Allemagne et Autriche il l'est ;
en Belgique la direction assistée sur le 1.3 n'est pas électro-hydrolique, c'est une direction assistée électrique, alors qu'en France la direction est électro hydrolique dessus  :roll:
 --> 93245km de pur plaisir...
Hors ligne BabyBoy
« Réponse #454 le: 06 mai 2006 à 12:34:58 »
ah c est bien possible mais j ai quand même un leger doute, peut etre si quelqu un a deja explorer le dessous et n aynt pas d IDS+ pourrait nous dire s il a remarqué quelque chose
Hors ligne jojo_971
« Réponse #455 le: 18 juin 2006 à 14:42:51 »
Question:  le Sportswitch ajoute-t-il des chevaux ?
Salut à tous!
Tout est dit dans le titre!
J'attends vos réponses et remarques
Merci @+
« Modifié: 19 juin 2006 à 11:21:01 par David91 »
Hors ligne Jim
« Réponse #456 le: 18 juin 2006 à 14:52:07 »
Reponse : NON
Cherche un peu dans le forum et tu trouveras toutes tes reponses.
Il y a eu deja plein de sujets la dessus
Leffe toi pas faire
Hors ligne David91
« Réponse #457 le: 19 juin 2006 à 11:21:44 »
Reponse : NON
+1 d'ailleurs je fusionne  :wink:
Hors ligne Stylewon
« Réponse #458 le: 17 juillet 2006 à 22:31:51 »
Voici la "definition" d'Opel
Le bouton Sport permet une conduite plus réactive en améliorant la réponse de l'accélérateur et en procurant une sensation plus proche de la route. Disponible en série avec le système IDS+, la boite Easytronic® et la boite automatique.
Avec SportSwitch®, vous bénéficiez d'un amortissement dynamique, d'une accélération, d'une direction et d'une transmission plus sportives.
 :wink:
- 206 1.4 HDI Phase 2
Hors ligne cutler95
« Réponse #459 le: 28 juillet 2006 à 15:50:18 »
bonjour a tous,
je vois que beaucoup d'entre vous on ce bouton dans leur astra.
Ayant commandé une 1l9 150 cosmo je me demande si je l'aurai ou pas??
merci :roll:
Hors ligne David91
« Réponse #460 le: 28 juillet 2006 à 16:12:23 »
bonjour a tous,
merci :roll:
Si tu prends des jantes 17" ou des 18" oui (ça va avec chassis sport)  :wink:
Hors ligne cutler95
« Réponse #461 le: 28 juillet 2006 à 16:15:23 »
non je n'est pas pris de jante 17 ou 18 avec ma version cosmo option (cuir,alarme,peinture metal)
Hors ligne David91
« Réponse #462 le: 28 juillet 2006 à 16:19:50 »
Donc pas de sport switch (sauf s'ils ont encore changé  :bizarre2:)
Je vais fusionner ton sujet dès avec le sujet "Chassis Sport : votre Avis" de la même section dès que tu auras lu ceci  :wink:
Hors ligne lionel.biehler
« Réponse #463 le: 28 juillet 2006 à 16:33:12 »
Exact tu ne l'aura pas sauf mofi d'OPEL.
Pour l'avoir 2 solutions :
1. Option châssis sport
2. Jantes 17 ou 18
Astra 150cv 5p cosmo
Hors ligne SC
« Réponse #464 le: 28 juillet 2006 à 16:40:40 »
2. Jantes 17 ou 18
ou 3. Boite Auto.  :cool2:  mais comme elle n'existe pas en 150cv. :cool2:
Astra J 5P 160cv BVA Cosmo - Gris Titane - Pack Cosmo ( GPS 500 + Jantes 18") - Pack Cuir - Pack Flexibilité - Pack Assistance - Plancher Plat - Roue de secours - Barre de toit + Attelage OPEL - Désiglage ASTRA à l'arrière
  • user Invités: 784 user Robots: 8 user Caché: 0 user Membres: 0
    Point Google Point Baidu (7)
